CISCO-FIREWALL-MIB:cfwNetEventsEntry
sneakster1
Does anybody know which ASA devices supports the MIB CISCO-FIREWALL-MIB and the
following OID:    1.3.6.1.4.1.9.9.147.1.1.2.2.1 , this Object looks like it contains the same information as the show conn command which lists all the connections traversing though the firewall
http://www.oidview.com/mibs/9/CISCO-FIREWALL-MIB.html
Access: Not-Accessible
Type:   CfwNetEventsEntry
An entry in the table , containing detailed information
 about an event. Note that this table may be sparse.
 If Network Address Translation is not enabled
 cfwNetEventInsideSrcIpAddress and
 cfwNetEventInsideDstIpAddress will not be instantiated
 in the row. If Port Address Translation is not enabled
 cfwNetEventInsideSrcIpPort and
 cfwNetEventInsideDstIpPort will not be instantiated
 in the row. Entries are added to this table at the
 same time that events are added to the cfwBasicEventsTable.
 These two tables may be configured to be different
 sizes so there may not be a one-to-one correspondence
 between rows in the two tables.
0 Replies 0
