cisco ISR4451-X/K9 not able to configure netflow
vaidyasagar15
I am not able to get flow on our Netflow server for cisco ISR4451-X/K9
ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S2, RELEASE SOFTWARE (fc2).
I used below commands but still not getting flow.
flow record v4_r1
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect counter bytes long
collect counter packets long
flow exporter EXPORTER-1
destination Y.Y.Y.Y
transport udp 9999
flow monitor FLOW-MONITOR-1
exporter EXPORTER-1
record v4_r1
interface GigabitEthernet0/0/1
description ***XXXXXXXXXXXXXXXXX***
bandwidth 153600
ip address X.X.X.X X.X.X.X
no ip proxy-arp
ip flow monitor FLOW-MONITOR-1 input
ip flow monitor FLOW-MONITOR-1 output
load-interval 30
negotiation auto
end
Mark Malone
see if there been seen in the router first rather than the app your sending it too
sh flow exporter statistics
you could try this as well , ihave it running on a lot of routers and it works fine
flow record LIVEACTION-FLOWRECORD
 match ipv4 tos
 match ipv4 protocol
 match interface input
 match flow direction
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect ipv4 dscp
 collect ipv4 id
 collect ipv4 source prefix
 collect ipv4 source mask
 collect ipv4 destination mask
 collect transport tcp flags
 collect interface output
 collect flow sampler
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
flow exporter LIVEACTION-FLOWEXPORTER-IPFIX
 destination x.x.x.x
 source Loopback X
 transport udp 2055
 export-protocol ipfix
 option interface-table
 option vrf-table
 option sampler-table
 option application-table
 option c3pl-class-table
 option c3pl-policy-table
 option application-attributes
flow monitor LIVEACTION-FLOWMONITOR
 cache timeout inactive 10
 cache timeout active 60
