Cisco LMS 4.2 Logging problem
islam.kamal
Level 10
Level 10
After logging to Cisco LMS and type the correct usrname and password , i get this error.
403 Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I need a good solution to fix this problem . All things are working ok and i do not get any errors when i have installed this version. Please I need help
islam.kamal
Level 10
Level 10
please any help  i need an answer ASAP
Hi ,
Try regenerating the SSL again, Follow the below link:
https://supportforums.cisco.com/message/3831028#3831028
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
