10-31-2007 09:17 PM
I just racked a Cisco MARS and connected to ETH 1. I booted up and configured an IP and gateway from the Linux command line. I get intermittent connectivity. I tried the other ethernet port as well as swapping cables. I even tried the second MARS we purchased. It will ping the GW about 10 times and then skips 30+ packets before pinging again. Am I missing something? I didn't see any commands to change the duplex or speed.
11-01-2007 04:08 AM
Hopefully you saw and followed Task 2 here?
http://www.cisco.com/en/US/products/ps6241/prod_release_note09186a008066e320.html#wp1112824
Also, are any type of errors being generated on the switchport(s) where you've connected the CS-Mars?
Steve
11-01-2007 07:11 AM
You may also want to test from the perspective of the switch you plugged the MARS into. Verify MAC-ADDRESS-TABLES for VLAN MARS assigned to along with IP ARP tables - possible dup IP.
