Cisco Network Assistant 6.2 -> WS-C2960X-24TS-L -> Front Panel Led status error
bachor1980
Hello.
I have just discover that CNA 6.2 have some problem with full support for C2960X. In may case there are 8 switches WS-C2960X-24TS-L and on all of them CNA have problem with presenting Front Panel led status view.
All information about port status are available thru CNA. Port settings\Runtime status show correct information. Also Web page management shows correct information. Problem seems to be only on Front panel view component.
Tested on 2 computers and the same situation.
Do I have to enable something on switch? Upgrade OS ?? Or it is CNA bug ??
bachor1980
6.3 version solve that problem
