Cisco Network Assistant and IE2000 Links
I am running CNA 6.3.3 on my network containing various switch models.
In the CNA Topology window I am able to see the links between all switch types except the IE2000s.
The IE2000s are present in the Topology but they are not showing the link to their neighbor.
CDP V2 is enabled. Sh cdp shows that CDP V2 is enabled and functioning.
I am able to create manual links between an IE2000 and its neighbor. But I would prefer to have the actual links show since they give additional information such as link state.
Any suggestions on getting the IE2000 links to show?
James
Mark Elsen
 Ref: https://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_network_assistant/version6/relnotes/ol32368.html#pgfId-699844
              - It seems that IE2000 is not in the Devices  Supported list.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
