Cisco Network assistant problem
jorgecorrales1
Community Member
Hi, I need help to this soft, I have CNA VER 5.3 and some devices display N/A Unsupported devices, how to remove that condition in my devices
smahbub
Level 11
Level 11
Check for the devices supported by Cisco Network assistant by referring the link given below:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version4_0/release/notes/OL10227.html#wp699844
I think that there is a bug filed for the same but no workaround available as of now if the device you have is present under the supported device section.
