Cisco Network Assistant Will Not Connect to 3825 Router Using http
Pat Gainer
Trying to use the CNA to connect to my 3825 router, in preparation for 2960x switches we are going to purchase. I cannot connect using http - read/write. It seems as though the username and password fail. I can however, connect Read – only Level 1, and the username and password work fine and I am logged in. Is there something I can check in the Router configuration for the Network Assistant to work?
Pat Gainer
Disregard. I figured it out myself.
It will be helpful for other community members to know the solution and cause, if can be shared.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
