Cisco Network Assistant
Mesrop
Hi All.
I have a problem with CNA 6.0(and more) version.
Shows this message. unsupported device 2960-L catalyst.I can't add this in community.
Help,please!
Hi there,
The are plenty of management tools out there, none identical to CNA however. It all depends on which CNA features you actually use.
You will get plenty of suggestions on this forum. Personally I like Opsview or Solarwinds.
If you want free monitoring and configuration tools, Cacti and Rancid and a good combo.
cheers,
Seb.
Seb Rupik
Hi there,
Check the release notes:
https://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_network_assistant/version6/relnotes/ol32368.html#pgfId-699844
...the 2960L is not listed as a supported model.
cheers,
Seb.
Thanks a lot Seb Rupik.
Can i use other management tools like CNA for 2960-L switch?
Hi there,
cheers,
Seb.
Thanks!
