Cisco Nexus 7000 Switch and TCP Window sizing
ergarci21
Can anyone here give me some insight where to find the configuration for TCP window sizing or scaling on the nexus 7000. Also does anyone know if the Nexus 7000 handles packet traffic through-put from things like CIFS differently or does it just pass the packet straight through.
fb_webuser
Level 6
Level 6
use "ip tcp window size xxxx" command in config mode, where xxxx is the variable = bytes....
with CEF enabled, it will fast switch the packets thru the switch....
Posted by WebUser Neeraj Jagga from Cisco Support Community App
