Cisco Prime 3.7 Switch stack Monitoring
Is there a way to prime to monitor and alert if a switch stack member goes down ?
Mark Elsen
 - Configure the following on the switch :
snmp-server enable traps
snmp-server enable traps stackwise
 Also use and or configure the Prime host as a syslog server  on the device. I think this will then generate an alert.
m.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
