CISCO PRIME INFRASTRUCTURE 2.2
rmajos001
Dear sir.
we have bought cisco prime infrastructure 2.2 and have just download the software:
Prime Infrastructure 2.2 Physical ISO Image (for GEN 1 appliance only)
PI-APL-2.2.0.0.158-1-K9.ISO
this is the first time we are going to install cisco prime.
the user have a server with all the recommend hardware specification for GEN1 and the OS installed is WINDOWS 7 professional.
will cisco prime infrastructure 2.2 run on this server without any problem?
waiting your sooner answer.
roger
Marvin Rhoads
No.
That image will only install and be supported on the Cisco-branded Gen 1 appliance (IBM OEM hardware).
The ISO is self-contained and designed to be installed on that bare metal server only. It includes a customized RHEL Linux distribution as the OS. It has built in and non-configurable drivers for the exact NICs, Hard Disk drive controller and configuration etc.
You should be getting version 3.1 in the open virtual appliance (ova) format and installing on a server with VMware ESXi.
Marvin Rhoads
No.
