10-30-2025 07:12 AM
I know we should have migrated by now, but we still have 2 physical GEN 2 Prime appliances with Prime 3.10 (primary + secondary).
A couple of days ago the High Availability broke between the Primary and Failover appliances. After doing the Readiness Check for HA, it seems that I’m unable to re-establish the HA connection because the disks IOPS is too low on the primary appliance.
Does anyone of you have some tips on how I could solve this issue?
Helen
10-31-2025 02:33 AM
- @helencloostermans You are probably at a dead end here ; perhaps you could reboot the primary appliance
and try again. If that doesn't help and because of the GEN2's no longer supported ;
I would advice to migrate the Prime installation to a VM (with or without HA)
M.
11-03-2025 04:46 AM
Hi, I already tried an appliance and CIMC reboot, but unfortunately that didn't help. On the CIMC, all Storage tabs are green and seem ok, but disk IOPS is still too low.
I suppose I'll have to migrate to a VM...
Helen
11-03-2025 04:59 AM
- @helencloostermans Probably the best thing to do indeed. If the issue is related to fragmentation and or prolonged
system usage then a complete re-install could possibly help. But because of the Gen 2
it's not worth the effort.
M.
