03-05-2016 03:23 PM
I hope that you are good. Can you please help me about a problems below:
I configured snmp trap in too switchs types:
WS-C2960+24PC-S that run ios 15.0(2)SE6 and switch catalyste 4500.
For the first typs,device types cannot appears in cisco prime(1.3 version).I can see that its name and its ios version.However, in the second types i can see device type and any authers values.
Can you please help me.
Best regards.
03-05-2016 03:32 PM
For the first typs,device types cannot appears in cisco prime(1.3 version).I can see that its name and its ios version.However, in the second types i can see device type and any others values.
Can you please help me for appears device type in cisco prime for switch WS-C2960+24PC-S .
Best regards.
03-06-2016 07:04 AM
Can you possibly provide a screenshot of what you are seeing on the two devices? It is not clear from your description.
The Cisco Catalyst 2960-24PC-S Switch is a supported device with Prime Infrastructure 1.3.
However that is a very old version - the current release is 3.0.2. I don't have any switches of that model in my network but I checked both older 2950G and newer 2960-X which I do have and they both appear fine in the current PI 3.0.2.
03-07-2016 04:57 AM
03-08-2016 02:05 AM
03-12-2016 05:08 PM
I hope that your good.
Please respend me, this point is verry critical.I can't find the switch WS-C2960+24PC-S in cisco prime switch type but i find them in all equipements but without severel options.
Thank you for find in attachement the captures.
Best regards.
03-13-2016 07:02 AM
This forum is not staffed by Cisco TAC. If your request is critical then your should open a TAC case.
