Cisco Prime LMS 4.1 - Monitoring events
cesarmg182
Dear all
I have a problem to see the events in the Cisco Prime, for example when an event occurs (port-shutdown) in the switch I receive this information:
Event Source
DFM
Description
Cisco  Command Monitoring -> Event Command Source: Command Line, Event  Config Source: Running, Event Config Destination: Command Source
Event Category
Other
Fault Last Updated At
07-Mar-2013 16:57:40
Event_Description
InformAlarm
Component
192.168.10.5: Cisco Configuration Management Trap
I don't see the details of the port that was done, or other deatiled that give aditional information abut the event. I have configured the Cisco Prime in this way:
- Admin > Network > Notification and Action Settings > Event Sets  :   I have marked all the events
- Admin> Network > Notification and Action Settings>Fault - Email notification : My mail is configured , I received alarms by mail.
- Admin> Network > Notification and Action Settings>Fault Notification Group  : is configured
Notification                      Group Name: TestSW4
Device List: 192.168.10.7 ; 192.168.10.6 ; 192.168.10.5 ; 192.168.10.253 ;
Event Set: All
Event Severity: Critical ; Warning ; Informational ;
Event Status: Active ;
Customer Identification:
The snmp was configured in the devices:
snmp-server system-shutdown
snmp-server enable traps
snmp-server community <community> RW
snmp-server host 192.168.10.x <community>
PLease your support or give some information to configure correctly the events and failures in cisco prime in order to see correctly
khassan
This community is for collaboration. Pls post your question in the following community:
Home --> NetPro --> Network Infrastructure --> Network Management --> Discussions
