Cisco Prime LMS 4.2 Polling Question
robert.kerns95
Greetings,
I'm in the process of deploying a Prime LMS 4.2 soft appliance, and I've been trying to locate whether the polling mechanism supports dependencies.  Basically, my company has several remote sites, and there's no reason to attempt polling of Switch A (which is behind Router A) if Router A is down.  I've looked through several of the PDF documents and searched these forums as well as a general Google search with no success.
Any assistance is greatly appreciated.
Rob
AFROJ AHMAD
Hi Robert,
As per my knowledege there is no such mechanism exist . As long the device is added in LMS  , LMS will try to poll the device , even though the device is down.
My suggestion is to suspend that device for time being for which you do not need polling or Alert and once it is back , you can Resume it.
To suspend a device:
Inventory > Device Administration > Manage Device State
click in Managed count , you will see the device list..
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Robert,
Thanks-
Afroz
My thanks, sir.  I appreciate your assistance.
