Cisco Prime LMS 4.2
I have installed Cisco Prime LMS 4.2 via OVA image with Linux Kernal. Request you to please let me know the is there any command or set of commands so that i can verfiy the installation are done correctly except show application.
ADM
Marvin Rhoads
At the time of install, a completion message will be generated to the console. Beyond that, "show application status LMS" is the best check (aside from actually using the system).
There is also a pretty lengthy installation log file created. It's usually only necessary to consult that in the event that one of those first two checks returns evidence of an issue.
