Cisco Prime Network 4.0
Has someone installed Cisco Prime Network on another distribution than Redhat ? I want to install a local demo and I have only RedHat trial.
What is the optimal mode of installation Prime Network ? Unit  + GW and DB on the same machine? I would like to install in the same machine, but
I´m not sure if it will run ok.
If this is the optimal assembly mode, which is the required bandwidth between  Unit, Gw and DB.?
Thanks.
Regards.
0 Replies 0
