02-18-2010 05:00 AM
how i can find out how the NIC is configurtion?
When i connect with the cli then i see only the ip adresse gateway netmask not more. How i can found maybe is 100 full or half or autoneg?
regards,
Murat
02-18-2010 06:55 AM
How do this this on a client PC varies according to whether you are using Windows or Unix.
Under Windows, you typically need to go into your network connections (in Control Panel or alternately via Network and Sharing Center in Vista/Windows 7) and choose the network adapter you are interested in. Right click on it to manage its properties. Choose "Configure" button and then select the "Advanced" tab. In that window should be a setting labelled "Speed and Duplex". You specific interface may vary since the exact layout can be modified by the adapter vendors driver files.
Under Solaris OS, use the "ndd" command:
If you have ce or bge interfaces, use kstat ce and kstat bge, respectively, to return NIC settings. All other interfaces may use ndd to determine NIC settings.
ndd example with hme0, assuming "instance" is 0:
# ndd -get /dev/hme link_mode
Interpretation:
0 -- half-duplex
1 -- full-duplex
# ndd -get /dev/hme link_speed
Interpretation:
0 -- 10 Mbit
1 -- 100 Mbit
1000 -- 1 Gbit
To query a different NIC, such as hme1, set the "instance" to 1, and then perform the link_mode and link_speed queries above.
# ndd -set /dev/hme instance 1
Note: the ndd commands above must be run as root. Otherwise, you will receive errors such as "couldn't push module 'hme0', No such device or address."
Of course at the switch end, you can execute "show interface status" from the CLI and get a reply like:
#sh int status
Port Name Status Vlan Duplex Speed Type
Te1/1 notconnect routed full 10G 10GBase-LR
If the duplex or speed were auto, there would be an "a-" in the appropriate column.
02-22-2010 12:42 AM
Hi mklemovitch,
thank you for your answer but i have a ACS appliance with windows but i can only connect with cli and i have only this command:
? List commands
backup Backup Appliance
dbcompact Datbase Compact
download Download ACS Install Package
exit Log off
exportgroups Export group information to an FTP server
exportlogs Export appliance diagnostic logs to FTP server
exportusers Export user information to an FTP server
help List commands
ntpsync NTP synch with predefined NTP servers
ping Verify connections to remote computers
reboot Soft reboot appliance
restart Restart ACS services
restore Restore Appliance
rollback Rollback patched package
set Set commands
set admin Set administrator's name
set domain Set DNS domain
set hostname Set appliance's hostname
set ip Set IP configuration
set password Set administrator's password
set time Set timezone, enable NTP synch or set date and time
set timeout Set the timeout for serial console with no activity
show Show appliance status
shutdown Shutdown appliance
start Start ACS services
stop Stop ACS services
support Collect logs, registry and other useful information
tracert Determine the route taken to a destination
upgrade Upgrade appliance ( stage II )
With show command i have this:
Cisco Secure ACS: 3.3.2.2
Appliance Management Software: 3.3.2.1
Appliance Base Image: 3.3.1.6
CSA build 4.0.1.543.2: (Patch: 4_0_1_543)
Session Timeout: 10
Last Reboot Time: Mon Apr 14 13:19:31 2008
Current Date & Time: 2/22/2010 09:39:51
Time Zone: (GMT+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna
NTP Server(s): xxx.xx.xx.x
CPU Load Free Disk Free Physical Memory
0.00% 19.0 GB 143 MB
Appliance IP Configuration
DHCP Enabled. . . . . . . . . . .: No
IP Address. . . . . . . . . . . .: xxx.xx.xx.xx
Subnet Mask . . . . . . . . . . .: 255.255.255.0
Default Gateway . . . . . . . . .: xxx.xx.xx.xx
DNS Servers . . . . . . . . . . .: xxx.xx.xx.x
CSAdmin running
CSAuth running
CSDbSync running
CSLog running
CSMon running
CSRadius stopping
CSTacacs running
CSAgent running
on the Switch site i see the configuration but on the ACS site not.
regards,
Murat
02-23-2010 06:21 AM
On the appliance, you are limited as to what you can do or configure by design. The thought is to mask features that don't specifically relate to the device's function as a security product.
You should be coming up as auto speed and auto duplex. "show interface [interface id] status" at the switch will confirm the link status.
