CISCO UC Sever Monitoring
Learnercisco
Hi Guys,
I am trying to integrate UCS Server CIMC Controller with prime infrastructure 3.7  via SNMP protocol. Prime Infrastructure is not able to understand the device Type. I tried to upload the MIB File but its not accepting the MIB and giving attribute error. i wan to monitor M220 and M240 power/memory/CPU Servers via SNMP for
CISCO-UNIFIED-COMPUTING-MIB.my
CISCO-UNIFIED-COMPUTING-TC-MIB.my
CISCO-UNIFIED-COMPUTING-FAULT-MIB.my
CISCO-UNIFIED-COMPUTING-NOTIFS-MIB.my
Any body face the same problem?
Thanks in advance.
pieterh
Prime is not a common SNMP network management system
device support is added through device packs
check the supported device list
also support may also be removed on a higher version
(added:) like UCS240 M3 is included in the CPI3.0 supported device list
