cisco view 5.5 upgrade package
abouhich
hello,
I use ciscoview 5.5, I have just added the module (REF: WS-X6148A-GE-TX, Catalyst 6500 48 port 10/100/1000 Frame w/Jumbo, RJ-45) to the switch Catalyst
6006. I use for this module the system (cat6000-supk8.8-5-3.bin).
I have download the package (Cat6000.cv50.v8-0.zip) that I have download from the (http://www.cisco.com/cgi-b
in/Software/CiscoView/cvresult.cgi?product_class=Catalyst20Switches&product
=Catalyst%206000&application=CiscoView%205.0%2C%205.1%2C%205.2)
but ciscoview cannot display this module (always no to support) .
thank you very much
frankzehrer
Level 4
Level 4
Please read the Prerequisites carefully and corrlate them with the failures: You have two failures stating that the CLIParser.cv50.v1-4.zip is not installed! At the moment you are running 1.3!!
Dependent Packages:
* CLIParser.cv50.v1-4.zip or later
* SwitchAddlets.cv50.v1-20.zip or later
* Entity.cv50.v1-7.zip or later
Please download these packages before installing the DV update.
Best regards,
Frank
hello,
can you tell me the coorect link to download those packages
many thanks
please use the softeare search tool at
http://www.cisco.com/cgi-bin/Software/SWSearch/SWSearch.cgi
Just paste the filnemaes in and download.
Best regards,
Frank
