Cisco Works LMS 3.0 install support over Virtual Machine
g_curuchaga
Hello, Could you tell me if the LMS 3.0 I can install in the virtual machine, how WMware o others.
regards
Guillermo
spasternacki
From technical perspective, you can install LMS3.0 on VMWare and it works, but as far as I remember virtual machine installs are still not supported by Cisco.
It can be changed in newer releases so please check release notes or confirm it with your delivery company.
If you work for channel partner, than confirm it with your Channel SE.
Joe Clarke
LMS 3.0 is not supported on VMWare. LMS 3.0.1 which is due out in December is adding support for VMWare ESX server.
