Cisco Works LMS 3.2 Topological View
dinesh joshi
I am using Cisco works LMS 3.2. In Cisco Works Topological View, The device which are connect to each other through GRE tunnel are showing
as standalone in Topological View. While checking in the router CDP neighbour that devices are showing in cdp neighbour but in topological view no connectivity is showing between them.
Please help if ayy one had gone through with the same problem before.
DJ
dosic
Have a look here:
https://supportforums.cisco.com/message/3152825#3152825
I've the same issue.
Try to upgrade CM till 5.1.4
It works for me.
dinesh joshi
After upgrading Campus Mnager 5.1.4 it working now.
Lot of Thanks,
DJ
