ciscoview not showing SPA-8X1GE-V2 modules in ASR 1004
d.hanshaw
Does anyone have viewing  problems for module in CiscoView for the ASR's?
I have made sure I have all the device and software updates.
Is the module too new to have a image in CiscoView?
Shows up fine in the device detailed report.
Marvin Rhoads
I don't have one handy to look at but if you have the CVGenericpackage v1.9 or later, those cards should be supported. Reference the package release notes.
If that's up to that level and it's not working you'll have to open a TAC case for troubleshooting.
