Ciscoview StackMaker failing
feraarjona
Community Member
I've been having problems with the Ciscoview Stackmaker utility lately. I have recently installed Ciscoworks 2.5.1 updated dec05.
The problem is that when you try to stack some devices together, it should show a list of all the possible stackable IPs/devices, but it will only show just one IP.
However, when working with another stack it seems to be working fine. Also, with LMS 2.2 these stacks were working fine.
I've attached some screenshots so you can have a clearer view of the problem.
Anybody knows what may be causing the problem?
Fernando
vmoopeung
Level 11
Level 11
not sure of the issue, check out the following link on building a stack, hope this helps :
http://www.cisco.com/en/US/products/sw/cscowork/ps4565/products_user_guide_chapter09186a00801bbf21.html#1014480
