Ciscoworks and Visio
jefvaneijk
I have saved the stencil and also the csv file from the network topology. How can i import these in VISIO 2003? I doens't seem that you can't import csv file into VISO.
Marvin Rhoads
MS removed that feature (import csv file) from Visio, Not sure if it was as of Visio 2003 or Visio 2002. I do know that Visio 2000 works. If you can find a back-level Visio installation, you can import there and bring it forward as a .vsd file.
