CiscoWorks HUM - Poller Report
tech_trac
At what time/schedule does the device report retrieve the MIB information
Is Device Report based on the data retrieved by Poller Report.
For how long does the HUM store the MIB information retrieved from all the devices. And can it be retrieved based on user defined criteria at any time in future.
Joe Clarke
The time interval depends on how often your poller runs, and when it was created. For example, if you create a default five minute poller at 12:30, then it will run at 12:35, 12:40, 12:45, etc.
Yes, all reports are based on the data retrieved by the poller. The device report is an amalgamation of all poller data for the various built-in templates.
Data can be retained on a configurable basis. The data purge settings can be found under HUM > Admin > Data Purge. By default, the 12 hour summarization data is kept for a year. But there are a lot of data purge metrics that can be configured.
As long as the data exists in HUM, you can access it via the HistoGraphIt portlet, or via reports.
