ciscoworks -- Intrenal error in communication channel
secureIT
Level 4
Level 4
Hi Netpro Team,
I am getting an error "Intrenal error in communication channel" while editing or adding/deleting snmp credentials
in common services...(LMS-3.x);
We tried restarting the ciscoworks services, but still getting the same problem.
Please help to resolve this problem
6 Replies 6
AFROJ AHMAD
download the Patch for this bug from cisco.com and apply it that should fix the issue.
CSCtd07131    DCR operations fail with communication error
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
can u pls help me out how to do so
Thanks for sharing the info Afroj..
Could a reinstall of LMS will help in resolving this problem ?? please revert...
regards
-Rajesh
Hi Rajesh,
If you are just facing the problem that you have mentioned in the Thread there is no point to Re-installed the LMS.
However if you are facing some other isssues as well then you can Re-installed it.
I hope Re-installed will fix the issue.
Afroj
Hi Afroj,
I am facing only this issue in my lms server..secondly installing LMS4.0 is cost involved or how is it ?? in that case a
simple reinstall will resolve this error is it ?? i know LMS 4.0 the complete Gui and all the tabs are different.
pls revert...
regards
--Rajesh
Yes, Re-installed should take care of the issue..
However here the links for Patch (CS 3.3  and CS 3.2..apply which ever is applicable)
http://www.cisco.com/cisco/software/cart.html?imageGuId=9EE33249152B32176193349929E47597B46DC3C5&i=rs
http://www.cisco.com/cisco/software/cart.html?imageGuId=0C4F05EB3894563EC7BEC44C3E7D494AC34E9B88&i=rs
Afroj
