Ciscoworks LMS 2.2 and RWAN
parthibanp
Can i know the latest patches for Ciscoworks LMS 2.2 and RWAN bundle(DFM,Campus Manager,RTM,RME,Ciscoview,cmf, IPM,ACLM).
Thanks in advance
frankzehrer
Level 4
Level 4
Hi Parthiban,
You have to lookt into the mentioned links. Search for the matching Version e.g. RME 3.5, ACLM 1.6 and so on. You will find the patches.
First you schould have a look if the LMS 2.2 Update 1 is installed.
Check the readme files of the other LMS part if the patch is needed or if you have to install something special before the patch!
e.g. the latest IDUs need the LMS 2.2 Update 1 .
Depending on your actual patchlevel some IDUs e.g RME IDU 13 need some extra steps from IDU 5. But habe a look into the readme files and the upgrade paths.
If you have a CCO Login have try here:
LMS 2.2 Update 1
http://www.cisco.com/cgi-bin/tablebuild.pl/lms
cmf (Common Services)
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one
DFM
DFM IDU 1.2.10
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-dfm
CM
IDU 11
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-campus
RME
IDU 13
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme
ACLM
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-aclm
CV
Additional Devices
http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi
RTM
1.4: http://www.cisco.com/cgi-bin/tablebuild.pl/rtm-14
1.3: http://www.cisco.com/cgi-bin/tablebuild.pl/rtm-13
Best regards and good luck,
Frank
