CiscoWorks LMS Question:
AhmedEl-Eraky
hello everyone....
I am running LMS 2.5
My current scenario is that people use a shared password to telnet to the network devices.
However, what I am looking for is the possibility of having for each user a private username/password, and each user will login using this username/password alone, whether this set of usernames/passwords residing locally on the devices or on a TACACS+ server.
And so is it possible for the LMS to publish reports about the changes done by each user on the routers/switches??
and so knowing what changes are being done by whom?
Really appreciate your replies.
Thank you
Joe Clarke
Yes, this is possible using the Change Audit report in RME. For best results, make sure each user has their own CiscoWorks login, and that all devices are configured to send syslog messages to the CiscoWorks server.
