ciscoworks lms3.1 -- netconfig job problems
secureIT
Level 4
Level 4
LMS 3.1,when i do a netconfig job for more than >5 devices, in the job tab the status is always showing as running. But when i do it for 2 or 3 devices as a batch it comes as successfull. Nevertheless the configurations are updated when more than 5 devices selected. We tried to reboot the server also. All the services are running in the common services>server>admin>processes tab.
Pls find enclosed the netconfigclient & jrm log files. We started the jobs around Tue Nov 17 07:00:03 hrs
2 Accepted Solutions
Joe Clarke
Are you using SSH to connect to your devices?  If so, then you are most likely seeing a known bug where SSH sessions can lock up either deploying a config, or fetching a config.  All of the known SSH bugs are fixed in LMS 3.2, but patches for RME 4.2 are available from TAC.  The bugs are CSCsv95235, CSCsx24218, and CSCsw88378.
Bug CSCsr93277 is only an annoying problem.  It does not cause any functional loss.  A patch is available from the TAC, or you can upgrade to LMS 3.2.
Joe Clarke
Hi Clarke,
Is this falling under the bug CSCsr93277 ? Can you please check the attached log file which is closely matching with this bug id...
