05-22-2008 06:45 AM
Am having problems with setting up new jobs in CiscoWorks's Net Config (under RME). After selecting the device category, I move on to select the devices.
I created a custom view of specific devices, and altough the group displays, wheni click on it, i dont get a device listing.
Also, when i click on "All devices" it shows me that "no entries found"
However, under Inventory > List devices, all the devices i require are listed as managed.
How do i correct this problem
05-22-2008 07:30 AM
Is this server integrated with ACS?
05-22-2008 08:07 AM
No its not.
Its running on a plain Windows 2000 member server. Theres nothing else running on it.
We dont have ACS deployed on our network
05-22-2008 08:49 AM
Please post the output of the pdshow command, the exact version of RME, and a screenshot illustrating the problem.
05-23-2008 07:57 AM
05-23-2008 08:07 AM
Ah, RME 3.5. Try restarting DIServer and IcServer. There is a known bug where they can lock tables in the database preventing device lists from being displayed.
Note: RME 3.5 will become end of support at the end of June of this year. You should seriously consider upgrading to LMS 2.6 or 3.0.
05-23-2008 08:14 AM
Restarted both services, still no joy. I get the same result
05-23-2008 08:19 AM
Try restarting all of dmgtd. If that does not work, post the logs under NMSROOT\lib\jrun\jsm-cw2000\logs.
05-27-2008 01:36 AM
05-27-2008 08:12 AM
According to this, you have a problem with your RME database. You need to reinitialize your RME database, or restore it from a known good backup. The command to reinitialize is:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=rme dmprefix=Essentials
