10-09-2006 01:28 AM
I am running QPM 3.2.3 and want to have router originated packets to be marked at "internet" precendence. For this we used the ACL + Routemap command before using QPM. Now that I want to use QPM I need to reverse engineer the QPM config and the CLI Command reference manual says that for PBR - "Router Marking Policies will be translated via an ACL / Routemap /match IP ACL / interface/ IP policy route-map" but what I see when I do the "View CLI" in QPM it always creates an ACL and Classmap bound to a policy map for it. ( which will not capture and mark those router originated packets ) How should I do the marking in QPM to get a route-map CLI command syntax???
10-13-2006 10:15 AM
WRR,CAR,GTS are supported on as far as Ciscoworks QPM3.2.3 marking policy is concerned.Refer URL
NBAR must be enabled on LAN ports on Cat6000(IOS) and 7600 IR when configuring CBQ
10-18-2006 03:55 AM
It seems the PBR is considered a legacy QOS implementation MQC is what is translated on modern platforms like the 2811 ISR.
