09-08-2008 06:27 AM
I'm running LMS 2.6 with RME 4.0.6.
The current situation is that the job simply fails, and doesn't appear to have polled anything.
Because I'm not aware of the exact service at fault, I stop and restart the CW daemon. This fixes the issue for a single daily run. All jobs after the first run fail.
I get a single email:
The following is the status of your Change Poller based Collection job:
Job ID : 1015
Status : Job Failed
Description : System config polling job
Details : https://nms.ArkansasElectric.com:443/rme/DcmaJobDetails.do?jobid=1015.192
Start Date and Time : Thu Sep 04 17:00:21 CDT 2008
End Date and Time : Thu Sep 04 17:00:21 CDT 2008
RME Server Name/IP : nms.ArkansasElectric.com
Execution Summary
Pending : 0
NotAttempted : 0
Successfull : 0
Failed : 0
Partial Success : 0
I'm pretty sure this all began after we had a disaster in our data center. I know the server CW runs on went down without being properly shut down, so that probably has something to do with it.
Does anyone have any advice, or knowledge about how to remedy the situation?
Daniel
06-16-2009 09:40 AM
What Daemon did you have to restart?
06-16-2009 09:54 AM
This was a while back, but I'm pretty sure I was referring to crmdmgtd.
06-16-2009 09:56 AM
Thank you. I have a little bat file for this. However, I will have to wait until after hours to run this since it shuts everything down and restarts it. I find it takes about 1/2 hour before the system is usable again.
