CiscoWorks running on compressed folder.
andrea.meconi
Level 2
Level 2
Hello.
We are using CiscoWorks LMS 3.2.1 on Windows. Can administrators compress the main folder CSCOpx?
Thanks.
Regards.
Andrea
Marvin Rhoads
It might work, the documentaiton is silent on it as far as I can tell.
I wouldn't advise it though. LMS generally only needs a couple of GB and is pretty performance-challenged when the underlying server hardware (including disk) isn't performing in top form.
Many thanks for your help Marvin.
Regards.
Andrea
