Ciscoworks Shadow drive
adam benigar
Does anyone know a way to direct the shadow folder in Ciscoworks to an external folder or drive.  I'd like to automate the backup of this folder instead of copy-n-paste to an external source.
Marvin Rhoads
You can't configure Ciscoworks to use something other than the shadow directory in the pre-defined location. Your best bet is to use separate backup software to backup that subdirectory to an external target or a script to copy the files periodically.
