09-21-2006 05:50 AM
Is there any way i can import the topology map from one system to another.
I have just built a new server as the old and is out of maintenance.
09-21-2006 06:42 AM
No way AFAIK.
It's all linked to deviceid's that are bound to be different.
Unless the databases on both systems are the same, then there is a directory for each user you want to transfer.
Cheers,
Michel
09-22-2006 12:38 AM
The databases are in the same directory structure, I have created two partitions on windows which is the same as the original server and all the ciscoworks dir are on drive 😧
09-22-2006 03:06 AM
If you copy the files from
\CSCOpx\campus\etc\users\admin
from one system to the other the campus maps should follow.
Don't do this unless both databases are the same!!
Cheers,
Michel
