Cli Tempate help on creating port config.
I am trying to finish up this CLI Template and having a hard time get the correct syntax.
This works as to select the port but it also selects routed port, what I need to do is add another check that says if port is part of vlan 10 also select it.
#if ($devicetype.toLowerCase().contains("3750"))
        #foreach ($Port in $PortList)
            #if ($Port.toLowerCase().contains("fastethernet"))
                interface $Port
                    "switch command goes here"
                 exit
          #end
#end
I found the variable vlanid, but cannot seem to add to the existing command for sucess.
#end
Thnking something like this..
#if ($devicetype.toLowerCase().contains("3750"))&& ($vlanid() .contains ("100))
interface $Port
exit
#end
#end
#end
