CLI
Sencyty
Hello guys is there any command to remotely check what switch port an ip is configured. or with the mac address to know the gig port for a user.
Thank you
   If the Layer 3 is configure on the switch, you can find the IP by using the comando "show ip arp". But, switches usually does not have Layer 3, then, you need to  look at your Layer 3 device (router or Switch Core).
 What you can do is find the mac address on the switch by using the commando "show mac address table".  This command may vary depending on the switch model and version but you can use exclamation mark in order to guide on the command.
Leo Laohoo
Does the switch support IP Device Tracking?
