Cluster Management Suite (CMS) 64 bits
jrochette
Hello everybody,
First, sorry for my bad english (I'm French !).
Then, i want to know if I can Run the soft Cluster Management Suite (CMS) on a 64 bits computer (Windows server 2008R2).
Someone has tried this with sucess ?
Thank you for your answer.
JérémY.
Vinod Arya
Sorry, but CMS seems to be a very old software, built in 2007. I am mostly sure it would not have any support available now, and mostly on a 64bit OS architechture.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
Also, this software is EOS/EOL long back and hence you would not find any support details and data, including any downloads and documents for this software.
