CM Error
djiragb1cco
When trying to display Topologies from CM, the following error message appears (see attached file). This error does not occur when trying to display topologie from the CiscoWorks server itself. I have stopped and restarted the services with net stop crmdmgtd and net start crmdmgtd commands !!!
MICHEL.HEGERAAT
Looks like a name resolution issue.
How do you connect to the server?
Does http://carine:1741/ work for you ?
Cheers,
Michel
