CNA - Cisco Network Assistant 5.7.6 issue
cbialobzyski
On the 2960s 5.7.6 does not allow me to to add  the device when running c2960-lanbasek9-tar.122-58.xx and higher.
WS-C2960-8TC-S     12.2(58)SE2           C2960-LANLITEK9-M
Seems to work fine with up to c2960-lanbasek9-tar.122-55.SE5
Anyone else having this issue and\or have ideas why?
Marvin Rhoads
It could be the later version of IOS changes the switch's reported SNMP sysObjectID. That's what CNA is looking for when deciding whether or not to support adding the device.
The LMS compatibility guide notes two different IDs for that switch model -1.3.6.1.4.1.9.1.1006 and 1.3.6.1.4.1.9.1.1364 - the latter with 12.2(55.1.31)EX3 or later
You can verify by snmpwalking one older and newer IOS switch.
bllang
Thanks for the heads-up. We will have a look at this.
