CNA Error - Unable to connect
friesen01
I've upgraded Catalyst 4510R+E with SUP8 to actual image 3.6. Now I get following error when I try to connect with the switch via CNA and HTTPS protocol.
Unable to connect. SSL handshake process failed. The secure connection through HTTPS could not established.
The debug output from the switch is:
000305: May 8 08:42:37.925: %HTTPS: SSL handshake fail (-6992)
000306: May 8 08:42:37.925: HTTP: ssl handshake failed (-40404)
Maybe someone has a solution for this problem.
kr
Mark Elsen
 - They can't agree on a common cipher or another SSL problem ; perhaps you need to upgrade CNA (too)?
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
latest version of Cisco Network Assistant. I think there is a problem with the key exchange switch - CNA.
 - Well in that case I would certainly open a ticket@TAC
M.
       Beauty and terror
      Just keep going
       No feeling is final
