CNA - Supported monitor resolutions?
NorskeskogTas
I have a matrox dual head 2 go device on my support PC which enables resolution 2048/768 over 2 monitors. Only problem is that CNA (v4) does not run in this resolution. Is there a fix for this or do I have to lower my res to run this application? (Seems to be a Java limitation as the display inside the windows is missing)
Cheers for any help.
NorskeskogTas
No worries I have found the answer. 1024x768 supported. Shame but there you are.
