Command "netconf-yang" doesn't open port 830
RAW1456
Greetings,
I am using a Cisco ISR4321 running IOSXE 16.06.04
I am trying to get started with NETCONF and according to every tutorial I've read the command "netconf-yang" should be enough to start the NETCONF service and open Port 830, however, trying to get the Router's capabilities via
ssh -s <user>@192.168.88.211 -p 830 netconf
returns
ssh: connect to host 192.168.88.211 port 830: Connection refused
An NMAP scan also doesn't list Port 830 as open.
The service is definitely running though:
Router#show platform software yang-management process
confd            : Running
nesd             : Running
syncfd           : Running
ncsshd           : Running
dmiauthd         : Running
vtyserverutild   : Running
opdatamgrd       : Running
nginx            : Running
ndbmand          : Running
I've been stuck on this for a while now and would greatly appreciate any hints as to what I'm missing here.
Mark Elsen
 - Check if this guide can help you :
           https://www.cisco.com/c/en/us/support/docs/storage-networking/management/200933-YANG-NETCONF-Configuration-Validation.html
 M.
Thank you, but that seems to be the exact guide I've been using.
As I understand it, it states that if AAA and Syslog/SNMP monitoring aren't required you only need the basic SSH configuration and the "netconf-yang" command for the aforementioned Capabilities check to work.
For troubleshooting it only states that if the test doesn't work, there may be a firewall blocking Port 830 but I've already tested the command while connected directly to the router.
My answer comes late, but may help the ones who fall on this page.
I recently got the very same behaviour after deleting some crypto keys (i know it is bad :))
To restore them, you can disable and reenable netconf like :
csr-hub(config)#no netconf-yang
csr-hub(config)#
*Jun  9 15:01:04.021: yang-infra: netconf-yang server has been notified to stop
csr-hub(config)#
csr-hub(config)#netconf-yang
The existing self-signed trustpoint cannot be used for NETCONF.
Delete it and create a new one? [yes/no]: yes
CRYPTO_PKI: setting trustpoint policy TP-self-signed-3222202584 to use keypair TP-self-signed-3222202584
csr-hub(config)#
My reply may come late to this as well, but THIS finally pointed me in the right direction. After reenabling netconf-yang, a log message notified me that it was using an old trustpoint certificate. I disabled netconf-yang, deleted the cert, and reenabled netconf-yang. I then tested SSH over port 830 from Prime, and it finally let me accept the certificate in Prime.
