Compliance Management in LMS 3.2
rick684_2
I'm having a hard time getting Compliance Manager to accept a "banner login" command I'm attempting to use on 6500 IOS switches. I've edited the template, tried cut-&-paste, looked for the archive file on the server to directly modify it (without success), among other things. I have this feature functioning correctly on CatOS switches, but can't seem to get it properly set on IOS switches. What's the limit, as far as the template is concerned, on the number of characters with this type of command? Where are the archive configs located on the server; in the "shadow" directory?
Rick
chris.mcgarrah
Not sure what you mean when you say "not accepting", but I had some trouble with compliance templates and checking banners.  My issue was with multi-line commands as mentioned in the last post of this thread: https://supportforums.cisco.com/message/638950#638950
Once I put the in the template it worked fine.  The thread is discussing LMS 2.6 but was applicable in my 3.2 environment.  Hope that helps.
