Conditional Logic Based on Command Output
johnstack8
Visitor
In an EEM applet I want to use the output of a show command to decide if I need to make a change.
Here's the command whose output that I want to use:
BGP-DC2#sh run | i ^ neighbor 9.9.9.9 prefix-list
neighbor 9.9.9.9 prefix-list announce out
The prefix-list will either be announce or no-announce, if the prefix list is no-announce then I need to run a command to change it.
I feel that there must be an incredibly easy answer to this question but I can't find anything. I suspect that I somehow need to use the regex command or the action command pattern option.
Thanks in advance for your help.
johnstack8
Visitor
I found this page [1] and it lead me to the following solution:
action 02.0 cli command "show run | i ^ neighbor 9.9.9.9 prefix-list"
action 02.5 set active_prefix_list "none"
action 03.0 regexp "prefix-list ([^ ]+)" $_cli_result result active_prefix_list
action 04.0 if $active_prefix_list eq no-announce
action 05.0   syslog msg "no-announce prefix-list in place, restoring announce prefix list"
action 06.0   cli command "conf t"
action 10.0 else
action 11.0   syslog msg "announce prefix-list in place, making no changes"
action 12.0 end
[1] http://wiki.nil.com/Regular_expressions_in_Embedded_Event_Manager_applets
Yep, that should work.  Though you may need to check your spacing.  Hard to know here as HTML may be messing with stuff.
