Config Archive Not Working
davepeat2
My config archive is not working. So I did a capture and what I  see is the switch do a TFTP Write request of file xxxx.200.245.cfg. The response is  (from the server) destination unreachable, port unreachable.
I  would assume this is a firewall issue, but I got on the server to a  command prompt, and did a netstat -ano and the server isn't even  listening on UDP port 69. It would appear that TFTP is NOT working, even though it isselected in the Transport Archive Settings
Any suggestions?
LMS 3.2. RME 4.3.1
davepeat2
The service on the server was changed from automatic to manual. I started it and it worked, then I c
hanged the service to Automatic and rebooted the server and it continues to work.
