Config Fetch Fails
krhashbarger
I have been getting the following error when I archive my configs: CM0151 VLAN RUNNING Config fetch failed. The configuraiton file is backed up fine, its just the vlan.dat file that does not work. my transport protocols are Telnet, then TFTP. I am using RME 4.1.1
15 Replies 15
I had this problem, too. I had about 250 devices Partially Collected because CW could not download the vlan.dat.
I just started a netconfig job for those devices.
The job ran the following command:
vlan database
vlan 666 name CiscoBug
exit
vlan database
no vlan 666
exit
Works fine for me =). The vlan.dat keeps on flash even if u delete the just created vlan with the "no" command.
Patrick
