Config Maker v2.6 Help
beekerc69
Not sure this is the right forum.
I'm trying to use Config Maker v2.6 to help me design a small business infrastructure. I use a Cisco 678 DSL modem for broadband connection to the internet which I currently have connected to a 1720 via WIC-1ENET that will be upgraded to a 2621 with an NM-1E. Thing is I can't find a 678 in the list of items in Config Maker, so I'm not sure if the program will help me build the IOS package properly. Does anyone know if there is a way to add the 678 or a workaround that will give an accurate infrastructure portrayal of it?
Brian
bbaley
Level 3
Level 3
Here is a the link of the supported modules for Config Make, hope this helps :
http://www.cisco.com/univercd/cc/td/doc/clckstrt/cfgmkr/cmakerrn.htm#xtocid7
